Einleitung
This guide will provide information on how to replace a Lenovo Think Pad Helix screen. Be sure to have a clean and large enough workspace to properly replace the screen. Mind you to replace almost all the hardware on ThinkPad Helix you have to take off the screen. So learning how to properly take off the screen will help future replacements.
Was du brauchst
Using a plastic opening tool or opening pick, gently pry the screen off.
Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
Lift the screen up slowly.
Open the clips of the ZIF connectors and gently grab the cable to pull it out.
3 weitere Personen haben diese Anleitung absolviert.
