Einleitung
This guide will give you step-by-step instructions on how to safely remove your Battery. The Battery is a device that stores energy for your laptop.
Was du brauchst
Remove the 8 screws holding down the back panel, using the Phillips screw driver #000.
Remove the 3 screws using the Phillips screwdriver #000. The screws are wafer-heads, size m2x4mm.
Fast fertig!
Abschluss
