Einleitung
This guide will give you the instructions needed to replace the laptop's cooling fan. The fan is needed to keep the laptop from overheating.
Was du brauchst
Remove the 8 screws holding down the back panel using the Phillips screw driver #000.
Remove the 9 wafer-head screws, size M2x4mm, using the Phillips screwdriver #000.
Fast fertig!
Abschluss
