Einleitung
This guide will show you the steps to safely remove the HDMI-USB Jack assembly from the Lenovo ThinkPad S431. The HDMI-USB Jack assembly is used to transfer audio and visual data.
Was du brauchst
Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
Use the opening tool to lift up the T shaped cover.
Remove the M2x3MM wafer head screw.
Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
Lift the chip to release the HDMI-USB jack assembly
