Zum Hauptinhalt wechseln
Lenovo ThinkPad T400 Hard Drive Replacement
Was du brauchst
  1. Lenovo ThinkPad T400 Hard Drive Replacement, Hard drive: Schritt 1, Bild 1 von 1
    • Safe Shutdown: Press the "Windows" button and select "Shut down" or simply turn off the power, by pressing the power button for about 3-5 seconds until the screen completely turns off.
    • If your system is working now, please make sure to save all of files while in progress.
    • With a force shutdown, the work that hasn't been saved can be lost.
  2. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the power cord.
    • Using the switch on the battery, slide and pull to remove it.
  3. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Using a flathead screwdriver, remove the two screws that are holding the hard drive cover in place on the back corner of the computer.
  4. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Use a flathead screwdriver to gently pry up the cover and remove it completely.
  5. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Use the pull tab on the hard drive to completely pull out the hard drive. Please pull out slowly and gently.
  6. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Using a #00 Phillips head screwdriver, remove all four screws on the hard drive cover.
  7. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the side bumpers from the original hard drive and place them on the new hard drive.
  8. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Snap cover onto the new hard driver and tighten the four screws with a #00 Phillips head screwdriver. Then insert it back into the computer.
    • Make sure the black tab is facing out, like when it was removed.
  9. Lenovo ThinkPad T400 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Put cover back on computer and tighten screws with a flathead screw driver.
Abschluss
At the end of this fix, you can plug in your computer/ attach battery and turn on the computer.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Washington State, Team S1-G3, Hope Summer 2018 Mitglied von Washington State, Team S1-G3, Hope Summer 2018
WSU-HOPE-SU18S1G3
3 Mitglieder
1 Anleitung geschrieben
2 Kommentare
OK thru Step 5. Then, the Phillips screws are neither visible nor accessible until after the side bumpers have been removed. Likewise, the side bumper replacement must be the last thing done before the drive re-insertion. A small nit-pik for an otherwise clear and helpful procedure. Thanks!
cyanth - Antwort
thank you for this, much easier than expected even for me…
mridgway89 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 61
Insgesamt: 9,542
