Einleitung
This guide will show you how to replace your CMOS battery.
Was du brauchst
Remove the Phillips #0-6mm screw.
Lift up the back cover to the RAM cards.
Pull the lock for the baterry to the left to unlock.
While holding the tab in the unlocked position, remove the battery.
Turn the computer over and open the lid.
Wedge the small metal spudger between the palm rest and the keyboard.
Lift up the keyboard, but be careful not to completely remove.
Wedge the small plastic opening tool underneath copper band and tilt back.
Remove keyboard to replace.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
