Zum Hauptinhalt wechseln
Lenovo ThinkPad T400s Keyboard Replacement
Was du brauchst
  1. Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T400s Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Remove the Phillips #0-6mm screw.
    • Lift up the back cover to the RAM cards.
  2. Lenovo ThinkPad T400s Keyboard Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T400s Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Pull the lock for the baterry to the left to unlock.
    • While holding the tab in the unlocked position, remove the battery.
  3. Lenovo ThinkPad T400s Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the three Phillips #0-6mm screws on the back panel.
    • These screws are marked with a keyboard symbol next to them.
  4. Lenovo ThinkPad T400s Keyboard Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T400s Keyboard Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T400s Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Turn the computer over and open the lid.
    • Wedge the small metal spudger between the palm rest and the keyboard.
  5. Lenovo ThinkPad T400s Keyboard Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T400s Keyboard Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T400s Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Lift up the keyboard, but be careful not to completely remove.
    • Don't lift the keyboard too quickly, there is a connector cable you must disconnect first.
    • Wedge the small plastic opening tool underneath copper band and tilt back.
    • Remove keyboard to replace.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 6-18, Maness Spring 2015 Mitglied von Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 33
Insgesamt: 1,573
