Einleitung
This guide will instruct you on how to replace the keyboard on your Lenovo ThinkPad T410s.
Was du brauchst
Flip the laptop over.
Push and hold the locking switch to the left.
Pull the battery out with your other hand.
Remove the single Phillips #0 screw grin the back panel.
Pull the back panel off.
Pull the metal prongs at the side of the RAM away from each other.
Pull the RAM out.
Remove the single Phillips #0 screw that secures the hard drive cover.
Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
Use the flat end of a spudger to unplug the keyboard connector from the laptop.
Pull the keyboard out.
