Einleitung
Is your Lenovo ThinkPad T410s mouse not moving or frozen? You might want to replace your palm-rest, and this guide will help you replace it!
Was du brauchst
Flip the laptop over.
Push and hold the locking switch to the left.
Pull the battery out with your other hand.
Remove the single Phillips #0 screw grin the back panel.
Pull the back panel off.
Pull the metal prongs at the side of the RAM away from each other.
Pull the RAM out.
Wedge the flat end of a spudger, or plastic opening tool, under the end of the keyboard and pry up.
Use the flat end of a spudger to unplug the keyboard connector from the laptop.
Pull the keyboard out.
Up the flat end of a spudger to lift up the black tab on the ZIF connector.
Pull out the ribbon connector from the ZIF connector.
