Zum Hauptinhalt wechseln
Lenovo ThinkPad T430s Display Replacement
Was du brauchst
  1. Lenovo ThinkPad T430s Display Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo ThinkPad T430s Display Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo ThinkPad T430s Display Replacement, Battery: Schritt 1, Bild 3 von 3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Display Replacement, Display: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T430s Display Replacement, Display: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T430s Display Replacement, Display: Schritt 2, Bild 3 von 3
    • Rotate your ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, remove the two 70 mm screws in the right and left corners.
    • Open the ThinkPad so the screen faces up. Lift the screen from its hinges.
  3. Lenovo ThinkPad T430s Display Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad T430s Display Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad T430s Display Replacement: Schritt 3, Bild 3 von 3
    • With the Phillips #0 screwdriver, remove the two 50 mm screws securing the plastic display case.
    • Wedge the flat end of the spudger in between the display case and the screen. Unsnap the top case from the bottom piece holding the screen.
    • Remove the case and set it aside.
  4. Lenovo ThinkPad T430s Display Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T430s Display Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T430s Display Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the four 30 mm screws holding the screen to the case.
    • Lift the screen out of the case.
    • Flip the screen over.
  5. Lenovo ThinkPad T430s Display Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T430s Display Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T430s Display Replacement: Schritt 5, Bild 3 von 3
    • Peel away the tape holding the cable down with the flat end of the spudger.
    • Pull the cable out of its socket.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 73
Insgesamt: 2,336
