Zum Hauptinhalt wechseln
Lenovo ThinkPad T431S Charging Port Replacement
Was du brauchst
  1. Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T431S Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 2
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Charging Port Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T431S Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the single, 3.0 mm screw with a Phillips #1 screwdriver bit that holds the charging port housing into place.
  3. Lenovo ThinkPad T431S Charging Port Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T431S Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Remove the small, white connector cable by prying it from the connector with a plastic opening tool.
    • Remove the charging port assembly.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 3,953
