Einleitung
This guide will show you how to locate and replace the Lenovo T431s fan. The cooling fan is what keeps your processing unit cool so the elements of your computer don’t overheat. If you are experiencing malfunction, overheat warning messages, or hot components, you might need to replace your cooling fan.
Was du brauchst
Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
Carefully pry off the back panel using the opening tool.
Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
Disconnect the cable attached to the fan, pulling the connector straight down.
Lift and remove the fan.
2 weitere Personen haben diese Anleitung absolviert.
