Zum Hauptinhalt wechseln
Lenovo ThinkPad T431S Hard Drive Replacement
Was du brauchst
  1. Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Lenovo ThinkPad T431S Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver to remove the eight 5.0 mm screws from the panel.
    • After loosening the screws, use the three opening tools to take the back panel off of the rest of the device.
  2. Lenovo ThinkPad T431S Hard Drive Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T431S Hard Drive Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T431S Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the single 3 mm screw holding hard drive bracket in place.
    • Grasp the hard drive and remove it from its bracket.
    • Use a slight wiggle motion to carefully disconnect it from the front prong.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Can I add SSD without removing HDD? in Lenovo T431s?
Usama Khan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 591
