Zum Hauptinhalt wechseln
Lenovo ThinkPad T440p Display Replacement
Was du brauchst
  1. Lenovo ThinkPad T440p Display Replacement, Display: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T440p Display Replacement, Display: Schritt 1, Bild 2 von 2
    • Flip the laptop over so that the bottom of the laptop is facing you.
  2. Lenovo ThinkPad T440p Display Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T440p Display Replacement: Schritt 2, Bild 2 von 2
    • Slide each of the battery latches away from each other into the unlocked location.
  3. Lenovo ThinkPad T440p Display Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T440p Display Replacement: Schritt 3, Bild 2 von 2
    • Slide the battery out of the battery compartment.
  4. Lenovo ThinkPad T440p Display Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T440p Display Replacement: Schritt 4, Bild 2 von 2
    • Flip the laptop over so that the top of the laptop faces you.
  5. Lenovo ThinkPad T440p Display Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T440p Display Replacement: Schritt 5, Bild 2 von 2
    • Lift the lid of the laptop until the top of the lid is touching the ground.
  6. Lenovo ThinkPad T440p Display Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T440p Display Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T440p Display Replacement: Schritt 6, Bild 3 von 3
    • Carefully pry the display bezels away from the display using the plastic opening tool.
    • The edges on the underside of the bezel that touches the display may be sharp.
  7. Lenovo ThinkPad T440p Display Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T440p Display Replacement: Schritt 7, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the four 3mm display screws.
  8. Lenovo ThinkPad T440p Display Replacement: Schritt 8, Bild 1 von 1
    • Carefully lift the display up and place it on the keyboard.
    • Don't remove it from the laptop. There's a cable still attached to it.
  9. Lenovo ThinkPad T440p Display Replacement: Schritt 9, Bild 1 von 3 Lenovo ThinkPad T440p Display Replacement: Schritt 9, Bild 2 von 3 Lenovo ThinkPad T440p Display Replacement: Schritt 9, Bild 3 von 3
    • Locate the latch attached to the display cable.
    • Grab the latch and flip it over so that it is facing away from you.
  10. Lenovo ThinkPad T440p Display Replacement: Schritt 10, Bild 1 von 1
    • Gently remove the cable from the display by pulling it directly away from you.
  11. Lenovo ThinkPad T440p Display Replacement: Schritt 11, Bild 1 von 2 Lenovo ThinkPad T440p Display Replacement: Schritt 11, Bild 2 von 2
    • Remove the display from the computer.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
UW Tacoma, Team S1-G19, Cardinal Summer 2020 Mitglied von UW Tacoma, Team S1-G19, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G19
1 Mitglied
1 Anleitung geschrieben
2 Kommentare
Easy peasy! Got a fresh 1080p IPS display into my ThinkPad thanks to this guide!
Noah - Antwort
What display did you have before? I have heard that there are two different display cables and if you didn't already have a 900p screen/already had a 768p screen, then you will need a new display cable to do the FHD display swap.
Annika Genisis -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 67
Insgesamt: 3,195
