Zum Hauptinhalt wechseln
Lenovo ThinkPad T440p Hard Drive Replacement
Was du brauchst
  1. Lenovo ThinkPad T440p Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Hard Drive Replacement, Back Cover: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T440p Hard Drive Replacement, Back Cover: Schritt 4, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two 9mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 1
    • Use a Phillips #0 screwdriver to remove one screw holding the hard drive.
  8. Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 8, Bild 1 von 2 Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Place the spudger underneath the hard drive mount and lift it up.
  9. Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 9, Bild 1 von 2 Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Remove the hard drive.
  10. Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 10, Bild 1 von 2 Lenovo ThinkPad T440p Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • Remove the hard drive from the plastic mount.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Christian Abad
1.378 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S6-G5, Peak Spring 2019 Mitglied von UMass Dartmouth, Team S6-G5, Peak Spring 2019
UMASSD-PEAK-S19S6G5
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 75
Insgesamt: 7,423
