Einleitung
If keys are unresponsive or the whole keyboard is unresponsive you will most likely need to replace the keyboard for your Lenovo ThinkPad T440p. Replacing the keyboard can be quite tedious but will mainly consist of unscrewing screws and using your spudger to lift and remove cables. When removing the plastic cover, remove carefully.
Was du brauchst
Using the spudger, move the plastic protector by pressing it down and forward in order to uncover the screws.
Unscrew the six screws that are attached to the keyboard by using a Phillips #00 screwdriver.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
