Zum Hauptinhalt wechseln
Lenovo ThinkPad T460s Heatsink Replacement
Was du brauchst
  1. Lenovo ThinkPad T460s Heatsink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Heatsink Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Heatsink Replacement: Schritt 3, Bild 1 von 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Heatsink Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T460s Heatsink Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T460s Heatsink Replacement: Schritt 4, Bild 3 von 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T460s Heatsink Replacement, Heatsink: Schritt 5, Bild 3 von 3
    • Remove the fan power cable in red square first.
    • Loosen all four 5.5mm Phillips #1 screws marked in red circle to take off the Radiator Assembly.
    • Those 4 screws can't be removed since all the screws have a retainer from the back
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 45
Insgesamt: 2,422
