Einleitung
In this guide, we show you how to remove and replace the base plate. This critical component provides a barrier of protection for the internal portions (RAM, connectors, speakers etc.) of a computer from outside factors.
Was du brauchst
Loosen the screws from the base plate.
Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
Once the screws have been loosened, start to remove the base plate.
Insert the iFixit opening tool into the space between the base plate and the chassis.
Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
Fully remove the base .
Grab the edge of the cover and lift the cover away from you.
