Zum Hauptinhalt wechseln
Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement
Was du brauchst
  1. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement, Base Plate: Schritt 1, Bild 1 von 1
    • Loosen the screws from the base plate.
    • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
    • These screws are captive - they will not fully come out after being unscrewed.
  2. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: Schritt 2, Bild 1 von 1
    • Insert the iFixit opening tool into the space between the base plate and the chassis.
    • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
  3. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: Schritt 3, Bild 1 von 1
    • Grab the edge of the cover and lift the cover away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  4. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement, Fan and Heat Sink Assembly: Schritt 4, Bild 1 von 1
    • Use a Philips #1 screwdriver to loosen the five captive screws that secure the heat sink.
  5. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the fan connector from its motherboard socket.
  6. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: Schritt 6, Bild 1 von 1
    • Gently lift the fan and heat sink assembly up and out of the chassis.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Reiona Silas
97 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 70
Insgesamt: 1,095
