Zum Hauptinhalt wechseln
Lenovo ThinkPad T495 Speaker Replacement
Was du brauchst
  1. Lenovo ThinkPad T495 Speaker Replacement, Baseplate: Schritt 1, Bild 1 von 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: Schritt 3, Bild 2 von 3 Lenovo ThinkPad T495 Speaker Replacement, Speaker: Schritt 3, Bild 3 von 3
    • Grip the speaker cable as close as possible to its motherboard plug, and pull directly backwards, parallel to the motherboard, until the plug releases.
  4. Lenovo ThinkPad T495 Speaker Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T495 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the three 1.6 mm screws.
    • Holding both sides, lift the speaker up and out.
Abschluss
UMass Dartmouth, Team 1-6, Petersen Spring 2022 Mitglied von UMass Dartmouth, Team 1-6, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 424
