Zum Hauptinhalt wechseln
Lenovo ThinkPad T495 Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: Schritt 1, Bild 1 von 1
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 1 von 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 2 von 3 Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T495 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
Abschluss
UMass Dartmouth, Team 1-6, Petersen Spring 2022 Mitglied von UMass Dartmouth, Team 1-6, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 778
