Was du brauchst
Remove the keyboard and the panel.
Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
Disconnect the orange and blue cables next to the left side of the speaker cover.
Remove the two 3mm screws on the left speaker with the Phillips #0 Screwdriver.
Using the Phillips #0 Screwdriver, lift the metal fastener up and remove the black and white wires.
Remove the two 3mm screws next to the lid hinges, as well as the two 3mm screws on the lid's ribbon cable.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
It was of good help, but be aware that you need to remove two screws on the back before removing the speaker cover. If not you will break the cover.
