Zum Hauptinhalt wechseln
Lenovo ThinkPad T500 Speaker Replacement
Was du brauchst
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: Schritt 4, Bild 1 von 1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad T500 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: Schritt 9, Bild 1 von 2 Lenovo ThinkPad T500 Speaker Replacement: Schritt 9, Bild 2 von 2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: Schritt 10, Bild 1 von 2 Lenovo ThinkPad T500 Speaker Replacement: Schritt 10, Bild 2 von 2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: Schritt 11, Bild 1 von 3 Lenovo ThinkPad T500 Speaker Replacement: Schritt 11, Bild 2 von 3 Lenovo ThinkPad T500 Speaker Replacement: Schritt 11, Bild 3 von 3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: Schritt 12, Bild 1 von 1
    • Remove the speakers.
Abschluss
nicO
15.927 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
34 Mitglieder
597 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,227
