Zum Hauptinhalt wechseln
Lenovo ThinkPad T530 External Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T530 External Battery Replacement, Place your laptop upside down: Schritt 1, Bild 2 von 2
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T530 External Battery Replacement, Unlock Battery: Schritt 2, Bild 2 von 2
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T530 External Battery Replacement, Remove the Battery: Schritt 3, Bild 2 von 2
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Angehängte Dokumente
Albert Stoynov
1.198 Reputation
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 99
