Zum Hauptinhalt wechseln
Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement
Was du brauchst
    1. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): Schritt 1, Bild 1 von 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement, Optical Disk Drive (ODD): Schritt 1, Bild 2 von 2
      • Turn your laptop over so the backplate is facing you.
      • Start with your Phillips #0 screwdriver and unscrew the 2 screws in each of the top corners of the backplate.
      • These screws should stay put on the backplate, and should not fall off.
      Frag FixBot
      Kommentar hinzufügen
    2. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 2, Bild 2 von 2
      • With your Phillips #00 screwdriver, simply remove the one 3mm screw on the upper left side.
      Frag FixBot
    3. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 3, Bild 3 von 3
      • Remove the ODD by using a plastic opening tool to push the drive out of the side of the laptop.
      • Make sure to place the tool where we removed the screw holding the drive in place in Step 2.
      Frag FixBot
    4. Lenovo ThinkPad W540 Optical Disk Drive (ODD) Replacement: Schritt 4, Bild 1 von 1
      • Once the ODD has popped out, simply grab and pull out the drive bay.
      Frag FixBot
Abschluss
Isaac
223 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 44
Insgesamt: 703
