Zum Hauptinhalt wechseln
Lenovo ThinkPad W540 Thermal Paste Replacement
Was du brauchst
    1. Lenovo ThinkPad W540 Thermal Paste Replacement, Opening the laptop: Schritt 1, Bild 1 von 2 Lenovo ThinkPad W540 Thermal Paste Replacement, Opening the laptop: Schritt 1, Bild 2 von 2
      • Unscrew all screws holding the back panel in place and disconnect the battery.
      • Now is a good idea to upgrade the RAM and also the CPU if needed.
      Frag FixBot
      Kommentar hinzufügen
    2. Lenovo ThinkPad W540 Thermal Paste Replacement, Removing the keyboard: Schritt 2, Bild 1 von 3 Lenovo ThinkPad W540 Thermal Paste Replacement, Removing the keyboard: Schritt 2, Bild 2 von 3 Lenovo ThinkPad W540 Thermal Paste Replacement, Removing the keyboard: Schritt 2, Bild 3 von 3
      • Push up the plastic trim around the keyboard keys.
      • Remove the several little screws that hold the keyboard and disconnect it.
      • Disconnect every single connector that you see.
      Frag FixBot
    3. Lenovo ThinkPad W540 Thermal Paste Replacement, Reaching the motherboard: Schritt 3, Bild 1 von 3 Lenovo ThinkPad W540 Thermal Paste Replacement, Reaching the motherboard: Schritt 3, Bild 2 von 3 Lenovo ThinkPad W540 Thermal Paste Replacement, Reaching the motherboard: Schritt 3, Bild 3 von 3
      • Remove the palmrest and disconnect the shown connectors.
      • Remove the 2 hidden screws that hold the display.
      • Remove all other screws.
      Frag FixBot
    4. Lenovo ThinkPad W540 Thermal Paste Replacement, The insides: Schritt 4, Bild 1 von 1
      • Insert wisdom here.
      Frag FixBot
    5. Lenovo ThinkPad W540 Thermal Paste Replacement, Changing the thermal paste: Schritt 5, Bild 1 von 2 Lenovo ThinkPad W540 Thermal Paste Replacement, Changing the thermal paste: Schritt 5, Bild 2 von 2
      • Unscrew the 7 screws holding the CPU heatsink and disconnect the fan.
      • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU. Also change the thermal pads.
      • Now is a good idea to upgrade the CPU if needed.
      • It is also recommended to use compressed air to remove any dust in the laptop and the fan. You can also open it to clean it from the inside.
      • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
      • Last, put the heatsink back carefully and tighten the screws in order 1 -> 7 to ensure even pressure. Dont forget to plug in the fan cable.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
The guide skips steps
Pyry300 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 30
Letzte 30 Tage: 94
Insgesamt: 4,206
