Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Battery: Schritt 3, Bild 2 von 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Fan: Schritt 6, Bild 1 von 1
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 7, Bild 1 von 1
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 8, Bild 1 von 1
    • Remove the fan by lifting it directly up.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: Schritt 9, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Disconnect all 10 of the ribbon cables attached to the motherboard.
  10. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 10, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 10, Bild 2 von 2
    • Disconnect the wire connecting the motherboard to the speaker.
  11. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 11, Bild 1 von 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding the metal covering over the power jack prongs.
  12. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 12, Bild 1 von 1
    • Use a Phillips #1 screwdriver to unscrew the 4mm screw holding down the Micro-SD card tray.
  13. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 13, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 13, Bild 2 von 2
    • Un-tape the orange and blue wires from the motherboard.
  14. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 14, Bild 1 von 1
    • Remove the black and grey wires from the cable comb on the motherboard.
  15. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 15, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 15, Bild 2 von 2
    • Use a Phillips #1 screwdriver to unscrew the 3.7mm screw holding down the wifi card.
    • Remove the wifi card.
  16. Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 16, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Power Jack Replacement: Schritt 16, Bild 2 von 2
    • Carefully remove the motherboard by lifting it and pulling towards the left.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Eevee Murdock
1.110 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S18-G4, White Winter 2020 Mitglied von Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
All going as described, until the final step trying to pull the motherboard out, and there is something still holding it in place. With a bit of a wiggle and pull, there is something about near the screw hole that was holding the wifi card down preventing the card from lifting there. Any clues?
Tim Ellison - Antwort
Answering my own question: Removing the motherboard requires that you first pop the SIM card / MicroSD card holder out of the socket, otherwise it won’t lift out. Submitted an update to the guide to save others falling into the same trap.
Tim Ellison -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 67
Insgesamt: 4,129
