Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Battery: Schritt 3, Bild 2 von 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement, Speakers: Schritt 6, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the four 4.6mm screws holding the speakers.
    • Each speaker has 2 screws.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the wire running from the right speaker to the motherboard.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 8, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 8, Bild 2 von 2
    • Remove the tape that is holding down the wire that connects the two speakers.
  9. Lenovo ThinkPad X1 Carbon (2nd Gen) Speakers Replacement: Schritt 9, Bild 1 von 1
    • Remove the speakers by lifting them directly upward.
Abschluss
Eevee Murdock
1.086 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S18-G4, White Winter 2020 Mitglied von Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 992
