Einleitung
This guide will show how to replace the Wi-Fi card on the Lenovo ThinkPad X1 Carbon 5th Gen, Type 20K3-S0DQ00 S/N PF-0VPYSA 1710. This will be helpful to users who are struggling with Wi-Fi issues. Replacing a Wi-Fi card can allow for Wi-Fi connectivity and for increased signal strength and range.
The device should always be powered off and disconnected from the charger when being worked on.
Was du brauchst
Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
Remove the back cover using the opening tool, leaving the laptop back exposed.
Use the opening tool to pry the edge and work your way around the perimeter.
Use the Phillips #1 screwdriver to remove the 1.2 mm screw that's holding the Wi-Fi card in place.
