Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: Schritt 2, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove the 1.2 mm screw that's holding the Wi-Fi card in place.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the white and black coaxial antenna cables from the Wi-Fi card.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: Schritt 6, Bild 2 von 2
    • Slide the card out to remove it from the laptop.
Abschluss
Gateway, Team 1-3, Saknee Fall 2021 Mitglied von Gateway, Team 1-3, Saknee Fall 2021
GCC-SAKNEE-F21S1G3
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 1,326
