Einleitung
This guide gives instructions to remove the back cover of the Lenovo ThinkPad X1 Carbon 6th Gen. This may be necessary if the cover is broken and needs to be replaced or if any internal components need to be accessed.
Before beginning, make sure the laptop is powered down, and the battery is below 25% charge.
Was du brauchst
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Jimmy to lift the cover directly up off of the locating pins.
Remove the back cover.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
