Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Back Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: Schritt 2, Bild 2 von 2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
  3. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
  4. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: Schritt 4, Bild 1 von 1
    • Take out the battery by lifting it from the top edge of the laptop, and then pulling away from the motherboard.
  5. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement, Fingerprint Scanner: Schritt 5, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
  6. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: Schritt 6, Bild 1 von 1
    • Remove the cover by grabbing it and gently pulling up and to the left.
  7. Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 6th Gen Fingerprint Scanner Replacement: Schritt 7, Bild 2 von 2
    • Use a nylon spudger to lift up the black bar that secures the cable.
    • Disconnect the ribbon cable from the fingerprint scanner by pulling the cable directly out.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Michael Megna
1.361 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S19-G4, White Winter 2020 Mitglied von Cal Poly, Team S19-G4, White Winter 2020
CPSU-WHITE-W20S19G4
3 Mitglieder
23 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,685
