Was du brauchst
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Jimmy to lift the cover directly up off of the locating pins.
Remove the back cover.
Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
Lift the battery from the bottom edge and gently slide it out of the connector on the motherboard to remove it from the laptop.
Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
Carefully remove the SSD by lifting it and pulling it out of the pins towards the battery of the laptop.
Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
In diesem Schritt verwendetes Werkzeug:Nylon Tipped Tweezers$4.99
Use nylon tipped tweezers, or your fingers, to gently pull the fan's power cable towards the SSD, disconnecting it from the pins.
Use a plastic opening pick to lift the fan mount.
Use your fingers to gently pull the fan diagonally away from where it is connected.
Turn the fan over to expose the interior.
If necessary, clean out the fan or wipe away and replace the thermal paste.
Remove each of the 7 main ribbon cables that connect the motherboard to the rest of the laptop.
Detach the last ribbon cable in the same way as before.
For the red and orange cables, use a spudger to lift the black plastic bar.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Place a spudger under the cables to disconnect them from the WLAN card.
Use a Phillips #00 screwdriver to remove the two 3mm screws that secure the IO bracket.
Lift from the location of the screw towards you. Then pull towards the screw side to remove the bracket.
Lift the white and black wires from their press on connections. Make sure to grab the connector head, not the wire itself
Using an iFixit SIM card screw head tip, apply pressure to the hole to disconnect the SD card slot from the device.
Use a Phillips #00 screwdriver to remove each of the four remaining 3mm screws securing the motherboard to the device.
Lift from the top of the motherboard towards you.
Pull away from the IO port side to remove the motherboard.
Use a PH0 screwdriver to remove the three 2mm screws holding the daughterboard in place.
Use a PH0 screwdriver to remove the two 2mm screws holding the USB port in place.
Carefully push the keyboard from the front, starting at the edge (Left edge is depicted).
7 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Thanks for posting that. What a project!
Excelente Pagina muy buen aporte
Simple, concise, great pictures and detail. This was a fun take apart. And now to put it all back after a keyboard replacement. 💾
