Einleitung
In this guide, you will learn how to replace the touchpad of a Lenovo ThinkPad X1 Carbon 6th Gen. This may be necessary if your touchpad is no longer working properly. If you are having issues with your touchpad, see our troubleshooting guide. Before replacing the touchpad, try updating or reinstalling the drivers first. Be sure to power off your device and disconnect it from any power source before beginning.
Was du brauchst
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Jimmy to lift the cover directly up off of the locating pins.
Remove the back cover.
Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
Take out the battery by lifting it from the top edge of the laptop, and then pulling away from the motherboard.
Use the Phillips #0 screwdriver to remove the 2mm screw that secures the cover of the fingerprint scanner.
Use a nylon spudger to lift up the black bar that secures the cable.
Disconnect the ribbon cable from the fingerprint scanner by pulling the cable directly out.
Lift the lever that secures the cable.
Pull the cable out to disconnect the ribbon cable that connects to the touchpad.
Use a Phillips #00 screwdriver to remove the four 1mm screws that secure the touchpad to the laptop.
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
Where do I get a new mouse pad after I have taken it off?
