Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Is your Lenovo ThinkPad X1 Carbon 7th Gen (Model number: 20R1000RUS) battery not working the way it used to? Use this guide to replace your battery so you can use your laptop for more hours.
The battery allows for your laptop to work without a power cord. Refer to our troubleshooting page to determine if your battery has gone bad. If your battery is swollen, take appropriate precautions.
After installation of the battery is completed, calibrate your new battery for best performance.
Ersatzteile
Keine Ersatzteile angegeben.
  1. You MUST go to BIOS settings (F1 on startup) and disable the built-in battery. Disconnect laptop from power source to avoid electric shocks. Flip the laptop over on a flat surface with the back panel facing up.
    • You MUST go to BIOS settings (F1 on startup) and disable the built-in battery. Disconnect laptop from power source to avoid electric shocks.
    • Flip the laptop over on a flat surface with the back panel facing up.
    • Remove five 5mm Phillips #0 screws from the edge of the back panel.
    • Insert an opening tool between the back panel and edge. Maneuver the tool around the panel, disconnecting the clips holding the panel in place.
  2. Lift the back panel away from the device, exposing the internals. When reassembling, prioritize the tabs on the side that does not have any screws. This ensures that the tabs do not break. When reassembling, prioritize the tabs on the side that does not have any screws. This ensures that the tabs do not break.
    • Lift the back panel away from the device, exposing the internals.
    • When reassembling, prioritize the tabs on the side that does not have any screws. This ensures that the tabs do not break.
  3. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Remove five 5mm Phillips #0 screws from the edges of the battery.
    • Remove five 5mm Phillips #0 screws from the edges of the battery.
  5. Remove the connector between the battery and the motherboard by using an opening tool to initially lift the back end of the connector up. Avoid metal tweezers to remove the connector as metal to metal contact can damage the device.
    • Remove the connector between the battery and the motherboard by using an opening tool to initially lift the back end of the connector up.
    • Avoid metal tweezers to remove the connector as metal to metal contact can damage the device.
  6. Lift the battery straight up and out of device. Lift the battery straight up and out of device.
    • Lift the battery straight up and out of device.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Tushar Sharma
239 Reputation
1 Anleitung geschrieben
Cal Poly, Team S19-G2, White Winter 2020 Mitglied von Cal Poly, Team S19-G2, White Winter 2020
CPSU-WHITE-W20S19G2
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 11
Letzten 30 Tage: 71
Insgesamt: 193
