Einleitung
Reasons for failure in the display on this device include physical damage and cracks or shatters, vertical or horizontal lines appearing on the display, a flickering display, an extremely dim display, or failure to produce all pixels correctly. If you are experiencing any of these issues, a display replacement should return your computer to full functionality. This guide will show you how to replace the display in your Lenovo ThinkPad X1 Carbon 7th Generation laptop.
Was du brauchst
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Remove the six 2mm screws from the display hinges using a Phillips #0 screwdriver.
Remove each of the cables connecting the display assembly to the motherboard:
A display cable on the left
Two coaxial cables in the middle
Two more cables on the right
Lift the computer up and rotate the display backwards until it is detached from the rest of the computer as shown.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
great guide! BUT the "index page" for the thinkpad x1 carbon 7th gen (Lenovo ThinkPad X1 Carbon 7th Gen) doesn't list it, so something is kind of broken...
