Einleitung
This guide will show you how to replace the keyboard in your Lenovo ThinkPad X1 Carbon 7th Generation laptop. Reasons for failure of your keyboard may include the keyboard becoming unresponsive, dust or particles stuck that must be removed to allow functionality of the keyboard, visible damage to the keyboard, or loosened keys. If you are experiencing any of these issues, a keyboard replacement should restore your laptop to working condition.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Restart the computer. When the Lenovo logo is displayed, immediately press enter, then press F1 to enter the BIOS Setup Utility
Use the arrow keys to select Config→Power.
Select "Disable Built-in Battery".
The battery will be re-enabled when the charger is connected.
Flip the laptop over on a flat surface with the back panel facing up.
Remove the five 5 mm Phillips #0 screws from the edge of the back panel.
Insert an opening tool between the back panel and edge. Maneuver the tool around the panel, disconnecting the clips holding the panel in place.
Use an opening tool to gently lift up the battery connector from its motherboard socket.
Remove the connectors with bar latches by lifting up on the small bar behind the port and pulling the circuit ribbon away from the port.
Remove the snap connectors by lifting straight up until the connection pops out.
Remove the latch connections by lifting the latch up, releasing the circuit ribbon.
Remove the seven 4 mm Phillips #0 screws that hold the motherboard in place
Remove the 3 mm Phillips #0 screw located near the fan.
Lift the motherboard with the fan still connected straight up and out of the device.
Using a Phillips #00 screwdriver, remove sixty-six 0.5 mm screws from the keyboard.
