Einleitung
This guide will show you how to replace the back cover of the Lenovo ThinkPad X1 Extreme Gen 1 laptop (model number 20MF-000LUS).
Prerequisite Only guide.
Was du brauchst
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
