Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Extreme Camera Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Camera Replacement, Speakers: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Camera Replacement: Schritt 3, Bild 1 von 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Camera Replacement, Battery: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Camera Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Camera Replacement, Display: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Camera Replacement, Display: Schritt 6, Bild 2 von 2
    • Gently take off the cover of the hinge of the computer with a combination of the opening tool and your hands.
  7. Lenovo ThinkPad X1 Extreme Camera Replacement: Schritt 7, Bild 1 von 1
    • Lift up the covering of the display using the opening tool.
  8. Lenovo ThinkPad X1 Extreme Camera Replacement: Schritt 8, Bild 1 von 1
    • Use a spudger to release the retaining flap on the cable connector.
  9. Lenovo ThinkPad X1 Extreme Camera Replacement: Schritt 9, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Camera Replacement: Schritt 9, Bild 2 von 2
    • Pull the wire that was connected to the retaining flap through the hinge.
    • Remove the display from the laptop.
  10. Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: Schritt 10, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Camera Replacement, Camera: Schritt 10, Bild 2 von 2
    • Detach the wire that's connected to the camera.
    • Remove the camera.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 652
