Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Extreme Charging Port Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: Schritt 2, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: Schritt 2, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement, Fan: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Phillips #00 Screwdriver
    $5.49
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  3. Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  4. Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 4, Bild 2 von 2
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  5. Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Charging Port Replacement, Charging Port: Schritt 6, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the two screws on the cover of the charging port.
  7. Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Charging Port Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the charging port cable from the motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 37
Insgesamt: 2,352
