Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Extreme Fan Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Extreme Fan Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Fan Replacement, Speakers: Schritt 2, Bild 1 von 1
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 3, Bild 1 von 1
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Extreme Fan Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement, Battery: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
  5. Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery out of the frame and remove it from the device.
  6. Lenovo ThinkPad X1 Extreme Fan Replacement, Fan: Schritt 6, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement, Fan: Schritt 6, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement, Fan: Schritt 6, Bild 3 von 3
    Phillips #00 Screwdriver
    $5.49
    • Unscrew the 3mm screw holding down the wireless adapter using a Phillips #00 screwdriver.
    • Slide the adapter out of its connector.
    • Detach the black and gray cables and separate them from the frame of the fan by gently pulling upwards.
  7. Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 7, Bild 2 von 2
    • Unlatch and remove the cable connecting to the frame of the fan by flipping the thin black tab up.
    • Separate the cable from the frame of the fan.
  8. Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 8, Bild 1 von 2 Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 8, Bild 2 von 2
    • Loosen the five screws connecting the fan to the motherboard using a Philips #00 head screwdriver.
    • These screws will not come out and will stay connected to the fan.
  9. Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 9, Bild 1 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 9, Bild 2 von 3 Lenovo ThinkPad X1 Extreme Fan Replacement: Schritt 9, Bild 3 von 3
    • Gently disconnect the two cables located on right and left side of the fan.
    • To identify these, they are labeled "FANR1" and FANL2" on the motherboard.
    • Lift the fan up and out and remove it from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Prabdil Sandhu
129 Reputation
1 Anleitung geschrieben
Cal Poly, Team S7-G3, Regan Winter 2020 Mitglied von Cal Poly, Team S7-G3, Regan Winter 2020
CPSU-REGAN-W20S7G3
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
You only need to complete steps 1, 8, & 9. The cables for the wireless card come out of the side of the fan assembly without unplugging them. If you want to disconnect the battery for peace of mind you can do that without removing the battery. Definitely don't need to remove the speakers. I came across this guide looking for a replacement fan part but have done this particular job twice and removed the fan on another occasion to bench test it, so I've done the process 3 times. Seems like the author was hunting for additional steps for more brownie points but it's much simpler than that.
Evan Looney - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 29
Letzte 30 Tage: 120
Insgesamt: 5,166
