Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Extreme RAM Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: Schritt 1, Bild 1 von 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: Schritt 1, Bild 2 von 3 Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: Schritt 2, Bild 1 von 1
    • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
    • Repeat the same process to the other side of the RAM.
  3. Lenovo ThinkPad X1 Extreme RAM Replacement: Schritt 3, Bild 1 von 1
    • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 1,025
