Einleitung
This guide will lead you through the steps to replace the trackpad on the Lenovo ThinkPad X1 Extreme Generation 1. The trackpad is used to control the device and may get worn down with age.
The removal of the trackpad requires you to first remove the battery, then proceed to remove four screws. Make sure the device is turned off before you begin these steps.
Was du brauchst
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
Set the speaker modules out of the way.
In diesem Schritt verwendetes Werkzeug:Flathead 1.5 mm Screwdriver$5.49
Remove the four screws that are holding the trackpad to the Thinkpad using a 1.5 mm flathead screwdriver.
