Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: Schritt 5, Bild 1 von 1
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: Schritt 6, Bild 2 von 2
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
Abschluss
Alex Shacoski
273 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S22-G3, Regan Winter 2020 Mitglied von Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Mitglieder
7 Anleitungen geschrieben
3 Kommentare
When you remove a heasink (or heat transfer pipe) from a chip, shouldn't you re-apply any thermal paste? Surely it had some?
Edward Dekkers - Antwort
after pressing power button Cooling fan runs for 2 sec then it stays off . What is the problem ?
Tonmoy Arafin - Antwort
Is there any upgrade that one can do to the fan or pipe except new thermal paste? I find it quite loud and inefficient. Isn't there a third-party one which is quieter?
Oliver - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 997
