Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement, Speakers: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement, Speakers: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    Kaufen
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: Schritt 5, Bild 2 von 2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X1 Yoga 2nd Generation Speakers Replacement: Schritt 6, Bild 2 von 2
    • Use your fingers to remove the speakers from the device.
Abschluss
Cal Poly, Team S22-G3, Regan Winter 2020 Mitglied von Cal Poly, Team S22-G3, Regan Winter 2020
CPSU-REGAN-W20S22G3
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 642
