Einleitung
This guide will take you through the steps of replacing the Wi-Fi Card on a Lenovo ThinkPad X1 Yoga 2nd Generation. The Wi-fi Card is an important aspect of any laptop because it is how the user connects the laptop to an available wireless network. Before beginning, make sure to power off your device completely and disconnect from any external power source.
Was du brauchst
Follow the ribbon cable that runs from the left speaker to the motherboard.
Pull the black connector up and release the cable wire by hand.
Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
Disconnect the gray and black coaxial cables from the Wi-Fi-Card using a spudger.
