Einleitung
This repair guide is to remove and replace the hard drive on the Lenovo ThinkPad X1 Yoga (Model Number: 20FQ005YUS). The hard drive is the storage for the computer; if your computer is running slowly or doesn’t have enough space to save documents, you may want to update your hard drive.
Warning: We recommend backing up your files onto an external drive or a cloud before replacing your drive, otherwise you won’t be able to access them!
Was du brauchst
Flip the computer over so the bottom is facing up.
Remove nine 4mm Phillips #1 screws from the bottom of the computer.
Use an iFixit opening tool to pry the back cover off of the laptop.
Gently peel back the black plastic covering.
Remove the single 2mm Phillips #1 screw from the hard drive's silver casing.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
