Einleitung
Use this guide to replace a noisy or burned-out fan.
Was du brauchst
Locate the screws on the back of the laptop. Unscrew all 7 screws using a magnetic screwdriver fit with a PH0 bit.
Please follow steps 3-6 from the Keyboard Replacement Guide, then return to this guide.
Using the magnetic screwdriver fit with a PH0 bit, unscrew the two screws shown in the picture.
Disconnect the two wired ribbons by pulling up the little black tabs, then pull the wires out.
Using the spudger, go beneath the frame to pry the frame off the device.
Place the frame aside once this step is completed.
Flip the device back over to untape the two black wires located at the bottom left corner of the device.
Using the same magnetic screwdriver, unscrew the two screws as shown in the picture.
Disconnect the plug right below the Fan. A pair of pliers might be useful during this step.
Then you are good to go.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
