Einleitung
This guide is for removing the ThinkPad X100e's LCD display and replacing it with a new one.
    • Use a Spudger tool to remove the screw covers on each side of the screen.
    • Be sure not to lose screw covers.
  1. Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
    • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
    • Pry open the bezel carefully with the spudger tool.
    • You will want to do this until the frame is completely off.
    • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
    • Be sure to set the screws aside on the magnetic mat.
    • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
    • The other two screws are located in the exact place on the other side.
    • Don't forget to place the screws on the magnetic mat, separate from other screws.
    • Remove the connector located at the very top of the screen beside the webcam.
    • To remove the connector, simply pull the connector out.
    • Fold the panel over until a strip of black tape is visible.
    • Peel the tape down until you get to the base.
    • Peel the piece of transparent tape back.
    • At this point there should be some exposed wires underneath the tape.
    • Remove the connector carefully with the spudger tool.
    • Remove the black tape fully.
    • Now your device is ready for a new panel.
Abschluss
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 188
