Einleitung
If certain keys on your keyboard fail to work or if it isn't working properly according to your laptop's Device Properties, keyboard replacement is probably necessary. However, this guide also acts as a predecessor to speaker replacement. Thankfully it is a simple replacement that only requires the use of a plastic opening tool.
Was du brauchst
Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
Flip up the ZIF connector that is holding the small ribbon cable in place.
Proceed to pull out the small ribbon cable
Flip up the ZIF connector that is holding the larger ribbon cable in place.
Proceed to pull out the large ribbon cable.
Eine weitere Person hat diese Anleitung absolviert.
4 Kommentare
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
